Added a small compass to the top center of the glareshield. It has compensation adjustments which might be needed after I do some heading checks. I'll also need to add a compass correction card.
Tightened up the lower fuel tank straps. A real squeeze getting under there.
Secured the lower ends of the crankcase and fuel tank vents.
Re-installed the F13-08 windshield strap that needed to be removed to install the glareshield screws.
Bundled more wires.
Started some fiberglass re-work on the lower cowling cutout for the right valve cover. I'd cut too much out on the initial cut.
